I can add multiple actions to a event?
zejio
Post by zejio »
I can add multiple actions to a multiples events?
I want to disable various folders when internet explorer and firefox are closed (no only one closed)
topix
Re: I can add multiple actions to a event?
Post by topix »
Here is one way. Copy & paste it into your config tree.
<EventGhost Version="1484">
    <Folder Name="Browser-check" Expanded="True">
        <Macro Name="check opened browser">
            <Event Name="Task.Destroyed.iexplore" />
            <Event Name="Task.Destroyed.firefox" />
                Window.FindWindow(u'iexplore.exe', None, None, None, None, None, False, 0.0, 2)
                EventGhost.NewJumpIf(XmlIdLink(793), 0, False)
                Window.FindWindow(u'firefox.exe', None, None, None, None, None, False, 0.0, 2)
                EventGhost.ShowOSD(u'IE & FF are down', u'0;-32;0;0;0;700;0;0;0;0;3;2;1;34;Arial', (0, 255, 0), (0, 0, 0), 4, (0, 0), 0, 3.0, False)
            <Action Name="IE and Firefox are closed, dow whatever you want">
                EventGhost.Comment()
        <Macro Name="IE or FF is opened" id="793">
                EventGhost.ShowOSD(u'IE or FF is opened', u'0;-32;0;0;0;700;0;0;0;0;3;2;1;34;Arial', (0, 255, 0), (0, 0, 0), 4, (0, 0), 0, 3.0, False)
zejio
Post by zejio »
Thx!
Sorry for my "noobness" :D but..how I can add this code to my config tree?
stisev
Post by stisev »
Copy (Control + C ) the entire contents of the "code" area (white area) and paste (CONTROL + V) into the main windows of EventGhost.
It should add all of the entries automatically after pasting.
Hot damn, Eventghost rules!
CollinR
Post by CollinR »
stisev wrote:Hot damn, Eventghost rules!
Agreed 8)
zejio
Post by zejio »
wow!works! :o
thx! ;)
