I am trying to send hex strings with the serial plugin but it is not working. I am not sure if I am sending the codes incorrectly or not. An example of what I am sending is: 81 01 04 00 03 FF. I know that there is not a problem with the port or the peripheral device because this code works when I send it with another terminal program. The Eventghost build is 0.3.5c. 908 and I am running Windows XP SP3. Would you happen to know what I am doing wrong?
Thanks.
Luc Werner
