Can not start ACDSee using Start Program command
JochenH
Post by JochenH »
When I try to start ACDsee 10 (Picture Organizer and Viewer) with the "Start Program" command, I get the Windows Vista message, that ACDSee does not work any more - a solution will be searched. :o
But I can start ACDsee by a normal double click on the application or a desctop icon (lnk-file). The program works fine under Vista. (I can produce the same error message, if I try to start the program in XP-SP2 compatibility mode using a desktop icon.)
I can start other applications without problems. I have also tried ACDSee 11 - the lastest version - the same problem exists. I have updated from 0.3.6.1449 to 0.3.6.1486 without change of the problem.
:?: Any idea what it may be?
Here the details:
EventGhost Version: 0.3.6.1486
SVN Revision: 580
Build Time: Mi, 12 Nov 2008 19:50:45
Python Version: 2.5.2 final 0
wxPython Version: 2.8.9.1
PIL Version: 1.1.6
Platform: Windows-Vista-6.0.6001-SP1
The message in the log file is:
Start Program: ACDSee10.exe
Task.Destroyed.WerFault
Task.Deactivated.EventGhost
Task.Activated.WerFault
Task.Created.WerFault
Task.Deactivated.WerFault
Task.Activated.EventGhost
Thanks - Jochen
topix
Re: Can not start ACDSee using Start Program command
Post by topix »
The same here. It seems ACDSee doesn't like it to be run from Commandline. When i go to Commandline and try to start ACDSee from there, it fails too.
JochenH
Post by JochenH »
topix wrote:The same here. It seems ACDSee doesn't like it to be run from Commandline. When i go to Commandline and try to start ACDSee from there, it fails too.
I have no problem starting ACDSee from command line. Runs perfectly. It is just fails from Eventghost.
Jochen
JochenH
workaround: Can not start ACDSee using Start Program command
Post by JochenH »
Just for anyone who has a similar problem a quick and dirty workaround.
First move a start icon (LNK-file) on top of your Windows Start menu.
Then have Eventghost execute an "Emulate Keystrokes: {Win}{Down}{Enter}" command, which will start ACDSee.
Jochen
