using activation exclusive.. How to desactivate it
fxvideonet
Post by fxvideonet »
Hello,i'm a french newbie and i'm trying to understand the "activation exclusive" fonction. I know it's for exclusively using an application, but how can i do for killed the exclusive process when i have finished to use the application and i want to use another one? I have read the wiki but i don't find an answer.
Thanks for your response
CollinR
Re: using activation exclusive.. How to desactivate it
Post by CollinR »
Make a folder
Put a folder for each application under that folder
Build your macros in these folders
Enable/Disable works on the folder tree, only one item in that folder may be enabled at a time. By enabling one folder you disable the others all you need to do is enable a different folder.
fxvideonet
thanks for your response, excuse me but what do you mean by "Enable/Disable works on the folder tree"??
I built a folder called "macros". In this folder, i have 2 folders, mediaplayer classic and windows mediaplayer, but after i don't understand what i must to do...
I'm very sorry
CollinR
Post by CollinR »
Okay so far you are doing fine.
In the folder /Macros create 2 macros:
1 enable exclusive and point it to the /Macros/mediaplayer classic/ folder
2 enable exclusive and point it to the /Macros/windows mediaplayer/ folder
Now whenever one is enabled the other is disabled and opposite is true too. Now you need to figure out what event to make the 2 newly created macros work.
Under autostart you might add a trigger event action that makes the event EnableWindowsMediaPlayer, the event will log as Main.EnableWindowsMediaPlayer each time EventGhost starts. Then you pick something else to trigger the media player classic macro.
fxvideonet
oki, thanks i'm going to try this....
Thanks for your help.
