Vista MCE and XBMC, how do I control both?
dabone
Post by dabone »
I've got XBMC setup with eventghost on Vista Ultimate X64.
I want to be able to control Vista MCE and XBMC with just the remote only.
Is there an easy way to do this?
(I.e. I want it to work alot like lirc on linux, i.e. when program a has focus, these buttons do this and no other commands are sent to other programs)
And is there a pluging for Vista MCE?
Later,
dabone
pbu50w
Re: Vista MCE and XBMC, how do I control both?
Post by pbu50w »
I would also like to do this. I'm almost there. I've got a set up which controls XBMC and what I need to do now is to create an event that makes the remote default to it's normal settings when I hit a certain button (as if eventghost wasn't running). Is there a way to do that?
In answer to part of your question, there is an XBMC plugin built into the latest beta which I am using and is quite useable.
