I am new to EventGhost and Python but have used them successsfully to control "my living room" but I am stuck.
Where do I find answers to the following:
1 How do I call an EventGhost macro from an EventGhost hosted Python script?
2 How do I call the Event Ghost function ShowOSD and other functions from an EventGhost hosted Python script?
Call EventGhost macros and functions from a Python script
peterlloyd
Re: Call EventGhost macros and functions from a Python script
A little example:
Have a look at Wiki: http://www.eventghost.org/wiki/Scripting
Tip: Create a Macro/Action, copy it (Strg-c) and paste (Strg-v) it into the script editor. This should help you to find out how to use EG-Actions in scripts.
<EventGhost Version="1486">
<Macro Name="<Unbenanntes Makro>" Expanded="True">
EventGhost.PythonScript(u'eg.globals.whatever = "Just a simple test"\n')
EventGhost.PythonScript(u'eg.plugins.EventGhost.ShowOSD(u\'{eg.globals.whatever}\', u\'0;-32;0;0;0;700;0;0;0;0;3;2;1;34;Arial\', (0, 202, 0), (0, 0, 0), 4, (0, 0), 0, 3.0, False)\neg.plugins.EventGhost.Wait(2.0)\neg.TriggerEvent("MyEvent")\n')
</EventGhost>Tip: Create a Macro/Action, copy it (Strg-c) and paste (Strg-v) it into the script editor. This should help you to find out how to use EG-Actions in scripts.
peterlloyd
Thanks for your helpful response. I understand your answer to my second question but my first question remains unresolved - If I create an EventGhost macro named XYZ, how do I just call/execute XYZ from a Phython script in another macro in the same xml file without replicating the contents of XYZ?
1) You can use Action "Jump" with (or without) option "and return after execution"
2) Try this example (Script 1 must be called as the first):Pako
<Folder Name="TEST 2 scripts" Expanded="True">
<Macro Name="Python Script 1" Expanded="True">
EventGhost.PythonScript(u"def myScript(txt):\n print txt\neg.globals.myProcedure=myScript\n#test:\neg.globals.myProcedure('Text 1')")
<Macro Name="Python Script 2" Expanded="True">
EventGhost.PythonScript(u"eg.globals.myProcedure('Text 2')")
</EventGhost>-
peterlloyd
Pako,
Thank you that helps a little but what I want to do would be like this with your example:
<Folder Name="TEST 2 scripts" Expanded="True"><Macro Name="Python Script 1" Expanded="True"><Action>EventGhost.PythonScript(u"def myScript(txt):\n print txt\neg.globals.myProcedure=myScript\n#test:\neg.globals.myProcedure('Text 1')")</Action></Macro><Macro Name="Python Script 2" Expanded="True"><Action>EventGhost.PythonScript(u'eg.EventGhost.Macro."Python Script 1"')</Action></Macro></Folder></EventGhost>
Here all I want is to repeat execution of macro "Python Script 1" by a call from the macro "Python Script 2" but this and other permutations do not compile.
Peter
Peter
