Problem with toggle commands
tomhanks
Post by tomhanks »
I have a philips SRM 5100 remote control, and I am using with eventghost and also XBMC.
It works but for each command I use for another one I have to press it 2 times, like a toggle command.
I notice that the green arrow in the tray gets red after each command.
Is there a way to make it work without this annoyance?
CollinR
Re: Problem with toggle commands
Post by CollinR »
Add both codes to your macro.
