Is the Dvico FusionHDTV Remote Supported by EventGhost?
tjb
Post by tjb »
I currently have a DVICO Fusion HDTV remote control and IR receiver that came with the Fusion Gold tuner card. DVICO refers to it as the Fusion MCE remote. Does anyone know whether or not this IR receiver can be used with EventGhost? Can I use the standard MCE plugin? I have a Harmony 550 remote on order that I hope to use with the Fusion IR receiver to control my HTPC.
