1487 problems...
1) Does not save the config... if I add/delete/disable any plug-in, macro, etc it does not save the setting. It does detect the changes and prompts to save... it just does not. Even if I choose the save button on the menu... no save.
2) lots of errors in the log... but alas they are all gone with 1479
error log from 1487, 1486, 1485 and who knows what other builds (none of these occur in 1479)...
Exception in thread Thread-5:
Plugin: Onkyo AV Serial
File "threading.pyc", line 486, in __bootstrap_inner
File "threading.pyc", line 446, in run
File "C:\Program Files\EventGhost\eg\Classes\SerialThread.py", line 343, in ReceiveThreadProc
WindowsError: [Error 6] The handle is invalid.
File "C:\Program Files\EventGhost\eg\Classes\ButtonRow.py", line 108, in OnOK
self.parent.OnOK(event)
File "C:\Program Files\EventGhost\eg\Classes\ConfigPanel.py", line 111, in OnOK
self.gr.switch(wx.ID_OK)
File "C:\Program Files\EventGhost\eg\Classes\UndoHandler\NewPlugin.py", line 48, in Do
eg.UndoHandler.AddActionGroup().Do(document, pluginItem)
File "C:\Program Files\EventGhost\eg\Classes\UndoHandler\AddActionGroup.py", line 56, in Do
folderItem = Traverse(parentItem, pluginItem.executable.info.actionGroup)
File "C:\Program Files\EventGhost\eg\Classes\UndoHandler\AddActionGroup.py", line 42, in Traverse
Traverse(folderItem, item)
File "C:\Program Files\EventGhost\eg\Classes\UndoHandler\AddActionGroup.py", line 52, in Traverse
item.__name__
File "C:\Program Files\EventGhost\eg\Classes\TreeItem.py", line 82, in Create
parent.AddChild(self, pos)
File "C:\Program Files\EventGhost\eg\Classes\ContainerItem.py", line 78, in AddChild
isValidId = self.HasValidId()
File "C:\Program Files\EventGhost\eg\Classes\TreeItem.py", line 187, in HasValidId
if not self.tree.IsExpanded(parent.id):
File "wx\_controls.pyc", line 5381, in IsExpanded
ValueError: invalid null reference in method 'TreeCtrl_IsExpanded', expected argument 2 of type 'wxTreeItemId const &'
Task.Deactivated.EventGhost
Task.Activated.explorer
Task.Deactivated.explorer
Task.Activated.Desktop
