Advice for better solution
BeerMeMore
Post by BeerMeMore »
XP Pro SP3, EG 0.3.6.1487
PC1=HTPC on port 1 of KVM running SageTV, USB-UIRT direct attached
PC2=Sandbox on port 2 of KVM
Gyration keyboard and remote/air mouse dongle attached to KVM USB port and swapped with KVM transfer.
Issue: Gyration device is accessed through HID plugin. Current config (listed below) works well on startup. KVM swap seems to cause mis-alignment when Gyration USB triggers System.DeviceAttached on hot swap. Restarting EG seems to resolve.
Brute Force Solution: Not elegant, but it works. On System.DeviceAttached event find EG and close application. Use AppMonitor to perform automatic restart of EG.
Given the simple script at this stage of my efforts, the restart is not noticible. However I expect to introduce more to EG and expect that this approach will ultimately be unacceptable. I would appreciate any alternative or oher creative suggestions for a better approach.
- <EventGhost Name="Configuration Tree" Expanded="True" Version="1487" Guid="{F988542A-8C3E-4460-8A5A-18EE0B6A1185}" Time="1231199594.1">
- <Autostart Name="Autostart" Expanded="True">
  <Plugin File="Serial" Identifier="Serial">gAIoSwBNgCVLA0sASwBLAIhYAgAAAFxycQBYBgAAAFNlcmlhbHEBdHECLg==</Plugin>
  <Plugin File="USB-UIRT" Identifier="USB_UIRT">gAKIiIiHcQAu</Plugin>
  <Plugin File="HID" Identifier="HID">gAIoWAUAAABGaXJzdHEAiImIVV1cXD9caGlkI3ZpZF8wYzE2JnBpZF8wMDAyJm1pXzAwJmNvbDAyIzgmZDlkY2E0NSYwJjAwMDEjezRkMWU1NWIyLWYxNmYtMTFjZi04OGNiLTAwMTExMTAwMDAzMH1xAU0WDFgIAAAAR3lyYXRpb25xAksCWB8AAABHeXJhdGlvbiBSRiBUZWNobm9sb2d5IFJlY2VpdmVycQNNIAKJdHEELg==</Plugin>
  <Plugin File="HID" Identifier="HID2">gAIoWAYAAABTZWNvbmRxAIiJiFVdXFw/XGhpZCN2aWRfMGMxNiZwaWRfMDAwMiZtaV8wMCZjb2wwMyM4JmQ5ZGNhNDUmMCYwMDAyI3s0ZDFlNTViMi1mMTZmLTExY2YtODhjYi0wMDExMTEwMDAwMzB9cQFNFgxYCAAAAEd5cmF0aW9ucQJLAlgfAAAAR3lyYXRpb24gUkYgVGVjaG5vbG9neSBSZWNlaXZlcnEDTSACiXRxBC4=</Plugin>
  <Plugin File="HID" Identifier="HID3">gAIoWAUAAABUaGlyZHEAiImIVV1cXD9caGlkI3ZpZF8wYzE2JnBpZF8wMDAyJm1pXzAwJmNvbDA0IzgmZDlkY2E0NSYwJjAwMDMjezRkMWU1NWIyLWYxNmYtMTFjZi04OGNiLTAwMTExMTAwMDAzMH1xAU0WDFgIAAAAR3lyYXRpb25xAksCWB8AAABHeXJhdGlvbiBSRiBUZWNobm9sb2d5IFJlY2VpdmVycQNNIAKJdHEELg==</Plugin>
  <Plugin File="HID" Identifier="HID4">gAIoWAAAAABxAIiJiFVeXFw/XGhpZCN2aWRfMGMxNiZwaWRfMDAwMiZtaV8wMSZjb2wwMiM4JjMxNzUwODA3JjAmMDAwMSN7NGQxZTU1YjItZjE2Zi0xMWNmLTg4Y2ItMDAxMTExMDAwMDMwfXEBTRYMWAgAAABHeXJhdGlvbnECSwJYHwAAAEd5cmF0aW9uIFJGIFRlY2hub2xvZ3kgUmVjZWl2ZXJxA00gAol0cQQu</Plugin>
  <Plugin File="HID" Identifier="HID5">gAIoWAUAAABGaWZ0aHEAiImIVV5cXD9caGlkI3ZpZF8wYzE2JnBpZF8wMDAyJm1pXzAxJmNvbDAzIzgmMzE3NTA4MDcmMCYwMDAyI3s0ZDFlNTViMi1mMTZmLTExY2YtODhjYi0wMDExMTEwMDAwMzB9cQFNFgxYCAAAAEd5cmF0aW9ucQJLAlgfAAAAR3lyYXRpb24gUkYgVGVjaG5vbG9neSBSZWNlaXZlcnEDTSACiXRxBC4=</Plugin>
  </Autostart>
- <Folder Name="HTPC" Expanded="True">
- <Folder Name="Equipment Power" Expanded="True">
- <Macro Name="Power Down" id="12" Expanded="True">
  <Event Name="Fifth.Button.1" />
  <Action>EventGhost.DisableItem(XmlIdLink(12))</Action>
  <Action>EventGhost.EnableItem(XmlIdLink(19))</Action>
  <Action>Serial.Write(u'\x02POF\x03')</Action>
  <Action Name="DenPower">USB_UIRT.TransmitIR(u'0000 006F 0000 0020 000A 001E 000A 0045 000A 001E 000A 001E 000A 001E 000A 0045 000A 001E 000A 001E 000A 001E 000A 001E 000A 001E 000A 0045 000A 0045 000A 001E 000A 001E 000A 06E5 000A 001E 000A 0045 000A 001E 000A 001E 000A 001E 000A 001E 000A 0045 000A 0045 000A 0045 000A 0045 000A 0045 000A 001E 000A 001E 000A 0045 000A 0045 000A 063C', 4, 0)</Action>
  <Action>EventGhost.StopProcessing()</Action>
- <Macro Name="Power Up" id="19" Enabled="False" Expanded="True">
  <Action>EventGhost.DisableItem(XmlIdLink(19))</Action>
  <Action>EventGhost.EnableItem(XmlIdLink(12))</Action>
  <Action>Serial.Write(u'\x02PON\x03')</Action>
- <Folder Name="External Vol (SPDIF)" Expanded="True">
- <Macro Name="Volume Up" Expanded="True">
  <Event Name="First.Button.233" />
  <Action Name="DenVolUp">USB_UIRT.TransmitIR(u'0000 006F 0000 0020 000A 001E 000A 0045 000A 001E 000A 001E 000A 001E 000A 0045 000A 001E 000A 001E 000A 001E 000A 0045 000A 0045 000A 0045 000A 0045 000A 001E 000A 001E 000A 0696 000A 001E 000A 0045 000A 001E 000A 001E 000A 001E 000A 001E 000A 0045 000A 0045 000A 0045 000A 001E 000A 001E 000A 001E 000A 001E 000A 0045 000A 0045 000A 068B', 4, 0)</Action>
- <Macro Name="Volume Down" Expanded="True">
  <Event Name="First.Button.234" />
  <Action Name="DenVolDn">USB_UIRT.TransmitIR(u'0000 006E 0000 0020 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 001E 000A 0046 000A 0046 000A 0046 000A 0046 000A 001E 000A 001E 000A 06B0 000A 001E 000A 0046 000A 001E 000A 001E 000A 001E 000A 0046 000A 001E 000A 0046 000A 0046 000A 001E 000A 001E 000A 001E 000A 001E 000A 0046 000A 0046 000A 06A3', 4, 0)</Action>
- <Folder Name="Swap Computers" Expanded="True">
- <Macro Name="Close on KVM swap back" Expanded="True">
  <Event Name="System.DeviceAttached" />
  <Action>Window.FindWindow(u'EventGhost.exe', None, None, None, None, None, True, 0.0, 0)</Action>
  <Action>Window.Close()</Action>
- <Macro Name="Swap to other PC" Expanded="True">
  <Event Name="HID.Button.554" />
  <Action>Window.SendKeys(u'{Scrolllock}{Scrolllock}', False)</Action>
