i have a question:
Is it possible to exit/quit/kill the process eventghost from inside, by pressing a button on the remote controll
lg h.
Exit EventGhost from Inside
Re: Exit EventGhost from Inside
Sure.
For example use "Find window" action and type in the executable name eventghost.exe. Then use the "Close application" action. You could also call an external executable like taskkill.exe or tskill.exe to do the same thing.
