virtual remote application
dbbd
Post by dbbd »
Using TCP receiver and sender, I was able to create a macro
triggered by a keyboard event, that sends a TCP event to a remote system
EG, which then performs some action.
Now I'd like some front end windows application, that presents a remote, whose
buttons can be clicked or keyboard in. This app will generate the local EG events that will
be sent to the remote system.
Does anything like that exist already?
Dan
topix
Re: virtual remote application
Post by topix »
Have a look at the plugin "DesktopRemote". Maybe that's what you looking for.
Here is a short example how to use it:
<EventGhost Version="1487">
    <Folder Name="OSR - Desktop-RC" Expanded="True">
        <Macro Name="Desktop Remote: Create New Remote">
                DesktopRemote.CreateNew(70, 30, 3, 3, 4, (128, 128, 128), (255, 255, 255), (78, 78, 78), u'0;-13;0;0;0;700;0;0;0;0;3;2;1;34;Arial', u'Remote Control', 1, True, True, True)
                DesktopRemote.AddButton({'width': 40, 'height': 30, 'event': u'1', 'label': u'1'})
                DesktopRemote.AddButton({'width': 40, 'label': u'2', 'event': u'2', 'height': 30})
                DesktopRemote.AddButton({'width': 40, 'label': u'3', 'event': u'3', 'height': 30})
                DesktopRemote.StartNewLine(0)
                DesktopRemote.AddButton({'event': u'Esc', 'label': u'Esc'})
                DesktopRemote.Show(10, 10, True)
        <Macro Name="Desktop Remote: Close" Expanded="True">
            <Event Name="DesktopRemote.Esc" />
                DesktopRemote.Close()
dbbd
Post by dbbd »
topix wrote:Have a look at the plugin "DesktopRemote". Maybe that's what you looking for.
</EventGhost>[/code]
Excellent! exatly what I need. Now, what do I enter as "events"?
Your example looks like the event is to issue a keyboard key. Can I send any EG macro (or rather an action)?
I'd like to send NetworkSender.Map(u'some string') events, but the syntax to use is not clear to me.
Dan
dbbd
Post by dbbd »
Ahh, now I get it.
Buttons just send events, (any string). Then you use these events in other macros with the actions you want.
Somewhat twisted, but it works ;-)
Dan
