Sending messages to EG (Winamp + Albumlist) - help!
stisev
Post by stisev »
http://albumlist.sourceforge.net/page.php?p=developer
Go to that URL.
For complicated reasons, pressing F3 to bring up the search albums dialogue is NOT an option. Thus, the only other choice that I have is to manually "send a message" to albumlist (winamp) from EG.
However, I'm having a lot of problems. I've never done this before, so my inexperience confounds the difficulty. :(
I want to use: IPC_JUMPTOALBUM to Brings up the 'Jump to Album' dialog.
I tried this entry, but it didn't work:
<EventGhost Version="1487">
        Window.SendMessage()
I don't know if this SendMessage() is doing anything. i entered IPC_JUMPTOALBUM but it doesn't let me save it.
Please help! :(
Re: Sending messages to EG (Winamp + Albumlist) - help!
Try this macro:
    <Macro Name="Find Window: Winamp AL" Expanded="True">
            Window.FindWindow(u'winamp.exe', u'Winamp AL', u'Winamp AL', None, None, None, True, 0.0, 0)
            EventGhost.PythonScript(u'from win32gui import SendMessage\nWM_ALL_IPC = 0x0400\nIPC_JUMPTOALBUM = 122\nSendMessage(eg.lastFoundWindows[0], WM_ALL_IPC, IPC_JUMPTOALBUM, 0)')
stisev
Post by stisev »
Thanks for the response. Hang on while I try it!
EDIT:
Pako, wow great! It worked!
Another Q: Let's say I wanted to add another function from:
WM_ALL_IPC = 0x0400
****IPC_JUMPTOALBUM**** = 122
SendMessage(eg.lastFoundWindows[0], WM_ALL_IPC, ****IPC_JUMPTOALBUM****, 0)
If I changed IPC_JUMPTOALBUM (the **** regions of the code), would it work?
Let's say I wanted to use IPC_PLAYRANDOMALBUM instead of JUMPTOALBUM. Would this work?
WM_ALL_IPC = 0x0400
****IPC_PLAYRANDOMALBUM**** = 122
SendMessage(eg.lastFoundWindows[0], WM_ALL_IPC, ****IPC_PLAYRANDOMALBUM****, 0)
I guess I could try it and see, but I would like to make sure there would be no adverse affects.
Thanks as always. You're an invaluable resource for this forum!
Sev
EDIT #2:
Apparently I answered my own question. It does (sort of) work, but with errors.
ERROR:
  Python script "16", line 4, in <module>
IndexError: list index out of range
EDIT #3: stand by :)
stisev
Post by stisev »
LOL. Sorry for my stupidity! Where exactly do I put that file. I didn't see any instructions on that site and Googled with no luck :(
topix
Post by topix »
He means, you should read the file. Then you will find that IPC_PLAYRANDOMALBUM = 102. The code would then look like this:
WM_ALL_IPC = 0x0400
SendMessage(eg.lastFoundWindows[0], WM_ALL_IPC, IPC_PLAYRANDOMALBUM, 0)
