[using version 0.3.5c build 908]
Must say EventGhost is a great tool.
I'm using a macro for testing of some IR controlled device.
my macro is running an endless loop, in order to stress my device.
I could not find a way to abort that endless loop.
any idea?
I'm really missing a "stop execution" button.
thank you!
-Itay
Is the a way to abort the currently running script?
Re: Is the a way to abort the currently running script?
I don't know a direct stop action, but one way could be to have a specific window open while the test is running. EG searches for the window and stops the macro if it doesn't find it. Here is an example what i mean:
The script loops between the two macros as long as an internet explorer window is found.
<EventGhost Version="851">
<Folder Name="endless" Expanded="True">
<Macro Name="Show OSD: Part 1" id="888">
EventGhost.ShowOSD(u'Part 1', u'0;-24;0;0;0;700;0;0;0;1;0;0;2;32;Arial', (255, 0, 0), (0, 0, 0), 4, (0, 0), 0, 1.0, False)
Window.FindWindow(u'iexplore.exe', None, None, None, None, None, False, 0.0, 0)
EventGhost.NewJumpIf(XmlIdLink(890), 2, False)
<Macro Name="Show OSD: Part 2" id="890">
EventGhost.ShowOSD(u'Part 2', u'0;-24;0;0;0;700;0;0;0;1;0;0;2;32;Arial', (0, 128, 0), (0, 0, 0), 4, (0, 0), 0, 1.0, False)
EventGhost.NewJumpIf(XmlIdLink(888), 2, False)
</EventGhost>Re: Is the a way to abort the currently running script?
many thanks for the reply. what you describe is exactly what I did before but I find it to be quite annoying.
I'm also wondering why no GUI way to create a loops and branches.
regards,
-Itay
regards,
-Itay
