Can you monitor VMC Sleep/Wakeup commands / states?
Shaolin23
Post by Shaolin23 »
Hi All,
I'm planning a new HTPC build around Windows Vista MC to supply audio to my Aton-DLA6 speaker router. The pc itself is going to be built on the MSI DIVA platform with integrated amp, and controlled via Sideshow and hopefully 2 Lilliput TFT's.
I'm hoping to use a USB-UIRT to send some IR commands to the DLA-6, namely power on/off.
My question is - Can I use EventGhost to monitor VMC's sleep / wakeup commands, then send the appropriate IR command to the speaker router?
Thanks in advance.
