USB-UIRT Noob Question
sling100
Post by sling100 »
Hi All
Apologies for the (probably) stupid question, but I can't seem to get my USB-UIRT plug in working.
I get this in the log:
Error starting plugin: USB-UIRT
Traceback (most recent call last) (851):
File "C:\Program Files\EventGhost\eg\Classes\PluginInfo.py", line 312, in Start
File "C:\Program Files\EventGhost\plugins\USB-UIRT\__init__.py", line 220, in __start__
File "ctypes\__init__.pyc", line 366, in __getattr__
File "ctypes\__init__.pyc", line 371, in __getitem__
AttributeError: function 'UUIRTSetRawReceiveCallback' not found
Am running Vista Home + EG 0.3.7.r851
Simon
sling100
Re: USB-UIRT Noob Question
Post by sling100 »
OK - an update.
Uninstalled the r851 version and installed the 3.6.1487 and all is now fine.
Was it just me?
Simon
specter333
Post by specter333 »
Hi Simon, I think it may have been some fluke, when I had r851 on my computer my USBUIRT seemed to work fine. I only went back until I have the time to redo the new format of events it logs. You should give it another try, especially before you create many macros with the old format that you'll have to redo later. Good luck.
