enable exclusives
lotus
enable exclusives
Post by lotus »
I have a Noob question. when I enable exclusives in a start program macro the exclusions stay forever after i exit the program. How do you turn them off and switch to another macro, event, etc...?
EG 0.3.7.r851
PS. I accidentally hit the new button and lost all the macro that come with EG like the mouse emulator. Is there any way to get them back?
jinxdone
Re: enable exclusives
Post by jinxdone »
Open the file Example.xml, that is the default config file shown after you install EG.
The 'enable exclusive' action simply enables/disables items in the configuration tree. If you go manually right click one of the disabled items there is an option to enable it again. Also there is a normal action for enabling/disabling items, but the enable exclusive oftens does the job better as you only need one action to disable and enable the right part of the config faster in one go.
TomXP411
Post by TomXP411 »
Anything in the AutoStart folder gets executed when EG starts up, so just add an EnableExlusive action in the Autostart folder.
