first of all.... eventghost rules ! i'm loving it!
Here is my "problem":
i would like to tell my asus display to switch to a specific video input (hdmi or dvi) using eventghost. to sad that the screen has no way of controling it (no ir, no serial) remotely.
The only "way" of controlling it is through ccd/ci using this tool: http://www.entechtaiwan.com/lib/softmccs.shtm
using ccd (on vista) with the above tool i'm able to switch the inputs "remotely" and therefore i've done some ugly findwindow --> send keypresses using evenghost.
Anyway... this is a very ugly solution and leaves me with the problem, that the asus display sometimes disables the ccd "extension" rendering my keypresses useless
Can anyone tell me if there is a better solution for my problem?
- does anyone know an extension or module for python in order to query a display using ccd and to send commands to the screen ?
- are there commandline utilities for my approach ?
i would really appreciate any help on this... as this drives me crazy!
Cheers
Marcel
