I have my computer set for a 1hr standby. Prior to actually entering into that mode, I want to close an application. On resume, I want to re-launch that application (XBMC).
thx
How to close application before Standby
Re: How to close application before Standby
There is a System.OnQuerySuspend event.
Windows will automatically try to shut down all open applications when sent a shutdown command.
Does that not close your application?
Hi all and thanks for your reply.
I don't want to shutdown my computer, I just want to put it to sleep and turn off all hard drive activity. I have configured my computer to go into standby in 30 minutes of inactivity. I'd like to shutdown XBMC because it crashes on standby recovery. How 'specifically' does one configure the System.OnQuerySuspend event?
thx
thx
You just have to connect it to an action.
Just set EG to show all events (checkbox in bottom left corner) and send your computer to standby and let it wake up.
You should see all the necessary events in the log.
