Using X10 New Icon Remote with Eventghost?
X10's new Icon remote does not come with a separate receiver which you plug into your pc like the older x10 Mouse Remotes, is it still possible to use this new remote with Eventghost please?
specter333
Re: Using X10 New Icon Remote with Eventghost?
The icon remote appears to be a normal IR remote. If so you can use any of the IR receivers and EG plugins, such as USBUIRT, with it.
