HI all am new to eventghost and need some help.
My set up:
Remote:MCE
OS: xp sp3
App 1:xbmc
App 2:GBPVR
I have xbmc set up fine all keys/launch buttons work. I also have Gbpvr keys/launch buttons working(up,down ect) and can launch both from the remote. My problem is when i switch to gbpvr from xbmc gbpvr doen't seem to be in focus the main menu loads but cant use remote and i cant switch back to xbmc. If i mouse click on gbpvr then i can use remote but can't switch back to xbmc. I have tried a few different actions but am new any info would be great thanks again.
I have added my xml file if that helps.
Need help with app switching
- htpc.xml
- (14.59 KiB) Downloaded 160 times
