EventGhost - XMBC Context Disabled after reboot
garysday
Post by garysday »
EventGhost v0.3.7.r851..
I have configured EventGhost to do exactly what I want it do to with regards to XBMC, however
when I either shutdown EventGhost OR reboot the computer then when EventGhost restarts the
XBMC settings under the context menu is disabled meaning I have to go and manually enable
this before my remote will work.. :(
Is there anyway I can get this to always be enabled upon reboot ?? Is there anything I am doing wrong.
Thx
Gary
garysday
Re: EventGhost - XMBC Context Disabled after reboot
Post by garysday »
*D'oh*
Need to disable "exclusive keyboard"
Problem solved ...
