Basic Question
Basic Question
Im very new to the whole EventGhost thing. I recently got into XBMC for my HTPC. I currently use a Harmony remote and found out that the Harmony software doesn't support XBMC the way I would like it to. Anyway, I was flipping through the Wiki on this site about how to use EventGhost. Im slightly confused on how it works with Harmony remotes. I use the Harmony software to tell the remote what to do, ie. turn on the TV, turn on the computer, etc... and then I use Eventghost to tell the computer what to do, ie. close BeyondTV and open XBMC when I press a certain button. I would assume thats how it works. But second thing, I have a USB reciever that apparently only shows up as a "Keyboard input" in EventGhost. It will only detect generic key presses, like numbers or left and right. It's this one: http://www.germes-online.com/catalog/93 ... eiver.html I was curious if anyone else had this, and had any suggestions on how to use it correctly in EventGhost?
Re: Basic Question
Pyoroi
I cant answer your question about your USB reciever
but:
I have made a pdf file that explains how I connected EventGhost, SageTV, Foobar2000, and my Harmony 880 remote to my HTPC
and a updated second one:
I have updated my guide to include the following
adding plugins, dragging and dropping commands,
copying items from some else's file, with SageTv and PowerDVD examples.
http://www.eventghost.org/forum/viewtop ... 7319#p7319
Scat
but:
Scat
