X10 cm17a Firecracker serial Plug in
drew750
Post by drew750 »
Has anyone been able to get the x10 cm17a Firecracker to work with the serial plug in. I have the 40 bit specifications (from the x10 website) for each transmission but I can't get it to work. I have seperated it into 5 - 8bit transmissions but still doesn't work. An example would be appreciated. Thanks
Post by Bitmonster »
I have no Firecracker, so I can't test this. But here is a Python module, that might help, if you understand some Python:
http://www.averdevelopment.com/python/x10.html
The mentioned pySerial module is already bound to EG, but under a different path. You will have to change the "import serial" in the source to "import eg.WinAPI.serial".
