I'm trying to create a macro/action to exit Spotify. The Find Window/Close doesn't help as Spotify gets in the tray and keeps running. You have to use the option Exit in the File menu or by right clicking the tray icon to exit it. How can I do to completely exit the application with Eventghost?
Sheugel
Completely exit an application (Spotify)
Re: Completely exit an application (Spotify)
You could use the hard way and use taskkill.exe to kill the application
