XBMC- scrolling goes super speed
rflores2323
Post by rflores2323 »
I am using a URC MX-810 remote that I programmed with a dummy dvd to send IR commands. I installed the XBMC plugin and I am learning how to get them to work correctly.
the problems that I have are:
1. when I press up/down or left/right the command comes up however it keeps repeating itself. So it keep scrolling very fast. I tried to put a delay however the problem still arises after the delay and the delay (wait time) makes it lag. I did this in both the xbmc plugin and also the keystroke emulator and it happens in both.
2. how do I get xbmc to open up automatically with a press of a button? I need it full screen as it tries to open in a window. Also can I have another button that I can press that can do multiple things at once for example... open xbmc>go to file library>and open search.
Livin
Re: XBMC- scrolling goes super speed
Post by Livin »
rflores2323 wrote:I am using a URC MX-810 remote that I programmed with a dummy dvd to send IR commands. I installed the XBMC plugin and I am learning how to get them to work correctly.
What XBMC plugin are you using? I suggest using Joni's
rflores2323 wrote:1. when I press up/down or left/right the command comes up however it keeps repeating itself. So it keep scrolling very fast. I tried to put a delay however the problem still arises after the delay and the delay (wait time) makes it lag. I did this in both the xbmc plugin and also the keystroke emulator and it happens in both.
What does the EG log say? Does it show it is receiving multiple IR inputs for that same command? If it it does, it is an IR input problem, not EG
If it does not, you have some strange issue - post a screen shot of your config for XBMC's directionals
rflores2323 wrote:2. how do I get xbmc to open up automatically with a press of a button? I need it full screen as it tries to open in a window. Also can I have another button that I can press that can do multiple things at once for example... open xbmc>go to file library>and open search.
This is all in Joni's XBMC plugin
