Error loading MCE Remote Plugin after Reboot
Every time i reboot my com the same error will occurs. Anyone knows the problem? Thanks
Re: Error loading MCE Remote Plugin after Reboot
The line 282 should be modified in the plugin, located in the file "plugins\MceRemote\__init__.py" of the EventGhost installation directory.
Actual contens of this line:
Can be modified to:
Regards
Prinz
could you try to increase the timeout of the plugin?qrsy2k wrote:Every time i reboot my com the same error will occurs. Anyone knows the problem? Thanks
self.msgThread.Start()Code: Select all
self.msgThread.Start(10.0)Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
CPU: Intel E5200
OS: WinXP SP3
hi thank you very much, it works.
