I'm running WinXP64 SP2 and have just updated EventGhost from 0.3.5c to 0.3.7r1076
and now my MS MCE V2 remote (RC6) is no longer working,
I use this replacement driver because I could not find any other driver for xp64.
How do I get it working again?
MCE remote no longer working after update from 0.3.5c
JustSomeUser
JustSomeUser
Re: MCE remote no longer working after update from 0.3.5c
Now I have solved the problem on my own
I just modified the MceRemote plugin from EventGhost 0.3.5c and now
it's working again with the replacement driver on my XP64
Also I add the files here if anyone is interested.
EDIT:
Just found out that if you comment the following line out in "plugins\MceRemote\__init__.py"
it's working so forget the above
EDIT:
def __start__(self, waitTime=0.15, disableHid=True):
#self.CheckHidState(disableHid)
self.msgThread = MceMessageReceiver(self, waitTime)
self.msgThread.Start(10.0)
- EventGhost_MceRemote_replacement_driver_for_xp64.7z
- (56.29 KiB) Downloaded 58 times
