Hauppauge IR vs MCE Remote
eli2k
Post by eli2k »
I bought a Hauppauge kit that came with an IR receiver and MCE remote. In EventGhost, is the correct plugin to load the MCE Remote or the Hauppauge IR? When I loaded the MCE Remote plugin, it works fine. If I load the Hauppauge IR, the log indicates that it cannot find the device.
- Eli
setup: windows 7 + EventGhost 0.5.0-rc4 + Intel nuc6i5syh
Prinz
Re: Hauppauge IR vs MCE Remote
Post by Prinz »
eli2k wrote:I bought a Hauppauge kit that came with an IR receiver and MCE remote. In EventGhost, is the correct plugin to load the MCE Remote or the Hauppauge IR?
In this case the MCE plugin is the right one.
The HauppaugeIR plugin should only be used, if the build-in IR receiver of the Hauppauge TV card is used.
Regards
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
eli2k
Post by eli2k »
Thank you for letting me know, Prinz!
