What is the Python command for input in EG?
eli2k
Post by eli2k »
I read in the changelog that "Replaced Python's built-in input() and raw_input() with a function that shows a simple input dialog." But it didn't indicate what is the function for capturing user input. The normal input() returns an error.
- Eli
setup: windows 7 + EventGhost 0.5.0-rc4 + Intel nuc6i5syh
Re: What is the Python command for input in EG?
Try this example:
myVariable = eg.SimpleInputDialog.RawInput('Enter some string...')
print myVariable
eli2k
Post by eli2k »
Thanks, Pako. That code works perfectly!
