I was looking through the sample configuration file that comes with EventGhost. Under "Start Zoom Player" there is an Event called DVD, and under "Start Winamp" there's another event called Music. Can someone explain how each of there events is triggered?
- Eli
Quick question on EG sample code
setup: windows 7 + EventGhost 0.5.0-rc4 + Intel nuc6i5syh
Re: Quick question on EG sample code
Bitmonster started to change the IR decoding so that hex codes are mapped to named events. I don't think he implemented this for anything other than the codes for the MCE remote. So instead of getting an event like "USB_UIRT.Rc6.0x800F0424", you get "USB_UIRT.Mce.DVD". That event would trigger Start Zoom Player. If you aren't using an Mce remote, or you are using one that isn't Rc6, you won't see those events, so you need to replace that event with one you will actually see. BTW, "DVD" will match any event "*.DVD".
Brett
Brett
Thanks; didn't know EG will match events like that. Good to know.stottle wrote:BTW, "DVD" will match any event "*.DVD".
