Firstly, great program. I lvoe the way you can just bring up the GUI press a remote button and then drag it to the event you want it to trigger.
I have a question as I seem to be having the opposite problem to some people. If I load event ghost then I was hoping that any event buttons I have not assigned would go through to the underlying code (in my case media center on vista home premium, all up to date). I have eventghost 0.3.7.r1076.
I have the Hauppage Nova-TD-500 and associated remote and am using it via the built in IR sensor. It operates media center mostly fine if I do not load eventghost, but once eventghost is loaded ALL remote events just stop at eventghost (unless I have assigned them to an action).
Is this expected behaviour, or is there a switch to allow all unassigned remote events to passthrough to the underlying system code?
Thanks for you time,
Ev.
