Onkyo volume OSD?
Thor
Onkyo volume OSD?
Post by Thor »
I wanted to use the return value I get from my receiver, to make a volume OSD on my screen.
My Onkyo 876 comes for example with the return "OnkyoSerial.MasterVolume 51" in the eventlog. But when I pull the task over to the Configuration, the figure "51" doesnÔÇÖt come with? It's only "OnkyoSerial.MasterVolume" that comes over, so it's not useful for making a OSD?
Why is that? And am I doing something wrong?
Thanks, Morten.
Bartman
Re: Onkyo volume OSD?
Post by Bartman »
The 51 is the payload of the event
Try
Onkyo Volume {eg.event.payload}
as the text
Thor
Post by Thor »
Bartman wrote:The 51 is the payload of the event
Try
as the text
:D Thanks, that works. There's no way that the payload number can be "translated" to the same db number that the receiver shows?
Bartman
Post by Bartman »
you can do all kinds of calculation in the curly braces
Thor
Post by Thor »
Bartman wrote:you can do all kinds of calculation in the curly braces
Got it working, thanks.
Another quick question, can I get the OSD to show me the time?
jinxdone
Post by jinxdone »
Sure. Use {eg.Utils.time.strftime('%c')}
You can find the tags you can use to format the time with strftime at http://docs.python.org/library/time.html
-jinxdone
Post by Bitmonster »
jinxdone wrote:Sure. Use {eg.Utils.time.strftime('%c')}
Clever idea to get around importing the time module, but this might break easily. So I've implemented a new object called "eg.StdLib" that allows you to dynamically access all standard lib modules directly. The above call should now be written in 0.3.7.r1170 as: {eg.StdLib.time.strftime('%c')}
