How to choose a receiver
ajaxmike
Post by ajaxmike »
I have a laptop that is running mediamonkey connected to the stereo and I will use eventghost to control it. I also have a Harmony 880 remote which is used for the TV, cable box, and stereo receiver. I could use as the 880 as the remote for eventghost or another remote would be OK too.
The USB-UIRT and the Tira2 are IR transmitting receivers, but they are more expensive than the MCE remotes or the X-10s. The RF remotes are attractive because they can be used out of the room, but they appear to be more expensive too and I can't use the 880 then.
How useful are the transmitting receivers? Are they really worth the extra money? Could an RF remote take the place of the 880 and control everything? Are any of the RF remotes/receivers also transmitters? Which remote/receiver should I buy?
