Use EG to send Hauppauge HDPVR power off/on via MCE blasters
meob
Post by meob »
Hi Guys,
long time lurker, noob poster!
I am looking into automating a power cycle of a hauppauge HD PVR,
The current driver for the HDPVR is a little flaky unfortunately, and needs a power cycle from time to time to sort itself out.
I am assuming this can be done manually using the hauppage hd pvr remote, so I am thinking this could be scripted / automated via event ghost?
What I wan to do is the following:
- teach EG the power on / off button command
- create a macro to send the command, possibly map it to a key press?
- once triggered the MCE blaster will send the command out the MCE blaster & send to HDPVR
I am just not sure if EG can be programmed to send IR blasts out via MCE IR buds?
and anyone confirm this?
Cheers!
ngibsonn
Re: Use EG to send Hauppauge HDPVR power off/on via MCE blasters
Post by ngibsonn »
Did you figure out a way to automate the power cycle of the HD-PVR? I'm having the same issue and would love to automate it.
