How do you avoid releasing win-key between events?
gibler
Post by gibler »
Let say I wanna change the volume on my tv with Keyboard.LWin+Right for higher.
If I liked to change the volume three steps in an old release I had installed before (0.3.6.rXXXX) I could press and hold the LWin-key and then tap on the Right-key three times. But now in the new release (0.3.7.r1194) I have to release the LWin-key after each tap on the Right-key otherwise Eventghost just show Keyboard.Right.
This only seems to be a problem with the Win-keys and only when they are added as an event somewhere in the configuration.
DonLuigi
Re: How do you avoid releasing win-key between events?
Post by DonLuigi »
I apologise for using an old thread but I have the same problem.
First Win+Right keypress shows: Keyboard.LWin+Right
While keeping Win pressed all the time, releasing Right and pressing it again shows: Keyboard.Right
Is this a bug or a feature?
Luka
