Return Case controlled commands
NikoMitDaMacht
Post by NikoMitDaMacht »
Hi!
Is there a possibility to create something like a cased jump with the return code of the last command?
Like:
FindWindow ...
Jump, if last return was 1, to ... --> do something
else --> do something else
DoSomething another thing...
I know that there is the possibility to jump only if the last command was successful, but ist there something like an else?
Is it possible to get the Returncode of the previous command in an other plugin?
Prinz
Re: Return Case controlled commands
Post by Prinz »
NikoMitDaMacht wrote:Hi!I know that there is the possibility to jump only if the last command was successful, but ist there something like an else?
I don't understand your problem. If the conditional jump doesn't fit, the next command after the conditional jump is executed. Why do you need a else command?
NikoMitDaMacht wrote: Is it possible to get the Returncode of the previous command in an other plugin?
[/quote]
The retuncode of the previous command is written into the global variable "eg.result". In this case a plugin or a python command/script can use the return code of the previous command.
Regards
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
