I want to use the HFX Vista GP remote with eventghost...
Which plugin do I have to select and how do I assign actions to the buttons?
Thanks for any help
Edit:
I tried some Generic HID and it works but some buttons still call the Windows Media Center, how can I disable this?
Or can I somehow use the MCE remote plugin where I can disable HID input?
Edit2:
I used the MCE Remote plugin which didnt work before and this time it recognized the generic hid and mce remote inputs but windows did as well so I tried to reboot the computer and made sure the hid is disabled...
however now only the generic HID is working again (altho the remote is deactivated under windows now)
I am using Vista64 with 0.3.7.r1194 UAC turned off and with admin account logged in
