Changes in SerialThread.py
m3flyin2lo
Post by m3flyin2lo »
I wrote a couple of plugins a few months ago, all using the serial port. They were written against the 0.3.6.1487 version.
I've recently upgraded to the latest version of EG (0.3.7.1194) and ran into some problems with my plugins.
I've tracked the issue down to one change in the SerialThread.py source: in the HandleReceive method, the "self.readCondition.notifyAll()" call was replaced with "self.readCondition.notify()". Because of this change, some of my Read calls do not return any data and time out.
I was wondering if there was a reason for that change. I am not sure if I am doing something wrong that would cause this change to break things. The sequence in my plugins where this is an issue is the following:
while r != result and tries<10:
            self.plugin.serialThread.Write(buffer)
            r = self.plugin.serialThread.Read(1, 5)
            tries = tries + 1
I am basically writing a command (buffer) and trying to read back the expected response (result). After the change in SerialThread.py, the response (r) is always empty. Before the change, the response was coming in fine.
Thanks.
