Disable all multimedia keys under Windows 7
bskchaos
Post by bskchaos »
Hi, I've just moved to Windows 7 and I need to disable all multimedia keys so they don't interfere with EventGhost.
I've always use the HID Plugin to handle everything and the keyboard plugin to kill those keys assigning them to a dummy macro, but under Windows 7 the keyboard plugin doesn't get anything from multimedia keys.
IceGothic
Re: Disable all multimedia keys under Windows 7
Post by IceGothic »
If not already done, you may wanna try:
http://www.howtogeek.com/howto/windows- ... ows-vista/
or this
Run gpedit.msc, then locate (can't remember in witch section it is) an item with "Win-X", and disable it
I know it disables the Win-* shortcuts, maybe it works on Multimedia buttons too.
