You get the newest official release here!
- Bitmonster
In this thread I will post every new release of EventGhost. So you can click on "Watch this topic for replies" and you will get an email everytime a new release is ready.
You will find a link to the newest release at the end of this thread, or you can use the normal SourceForge download page.
Some other links related to EventGhost:
EventGhost Wiki
EventGhost Homepage
EventGhost Summary on SourceForge.net
EventGhost Wiki
EventGhost Homepage
- Bitmonster
Changelog 0.1.3 (build 279):
+ New group 'System/Sound Card Control'. Currently only some functions to
control the mute state of the sound card are there, but more will come in the
future.
+ Added mouse functions:
Left mouse button double-click
Right mouse button double-click
Toggle left mouse button
These are mostly added to support remotes like the ATI Remote Wonder, that has
seperate events for double-clicks.
+ New USB-UIRT plugin.
+ New Joystick plugin.
(It was added in build 276, but I mention it here for completeness).
- Some bugfixes.- Bitmonster
Changelog 0.2.1 (build 356):
+ The Python editor now supports auto-indentation.
+ "Jump if" actions now have a more descriptive default label.
+ The updaters now include the full EventGhost source code. So users that are running the program from source will also have the newest version.
+ Added a plugin for the UIRT2. Receiving and transmitting is working, but there is currently no learn-dialog for sending ir codes. So you have to paste learned codes from the Girder3 plugin to this plugin.
+ Added two actions to control the master volume of the soundcard:
1. Set Master Volume: Sets the master volume to an absolut volume level
2. Change Master Volume: Increases or decreases the master volume by a given percentage
- some Bugfixes- Bitmonster
Changelog 0.2.2 (build 368):
+ Rework of the keyboard emulation. Many keys should now work better, especially if you are only controlling the frontmost application.
+ You can now combine keys with the plus-sign or minus-sign in addition of the underscore. These key labels in curly brackets are also case-insensitive (which is very seldom in EG). I suggest you use the plus-syntax from now. So instead of writing for example {ALT_TAB}, you should hence write {Alt+Tab} and {Ctrl+F}.
+ Added a new menu command "Edit->Rename" with F2 as hotkey, to enable easier editing of item labels.
- some bugs fixed (and most likely introduced some new ones) :)
- Bitmonster
Changelog 0.2.3 (build 385):
+ You can now copy events in the logger and paste them into macros.
+ You can now also drag events from the logger to the configuration tree
and drop them into macros.
+ Through these new copy&paste and drag&drop features it now makes less
sense to assign an empty event to a newly created macro, so this
behaviour has been dropped.
+ If you double click an action in the logger, the corresponding item
in the tree will be selected.
+ Updated the GUI toolkit to wxPython 2.6.2.1
+ New plugin for the "Streamzap PC Remote" from www.streamzap.com
+ The add-plugin-dialog now uses HTML to show the description of the
plugins. This way it is possible to add links/pictures/tables/etc
to the description.
+ The add-plugin-dialog know remembers size, position and layout.
- The "Network Receiver Plugin" should now be compatible to NetRemote.
- Bitmonster
Changelog 0.2.4 (build 386):
- Bugfix: EG could generate masses of errors if you had something
XML-like-looking in the clipboard.
- Bugfix: Newly dropped or pasted events from the logger were not
reacting before EG was restarted.
- Bugfix: It was possible to copy the Autostart item and paste it
into the tree. This would create an illegal configuration.
- Bitmonster
Changelog 0.2.5 (build 437):
+ New action: "Wake on LAN" to turn on another computer connected to the
local network.
+ New action: "Stop if" that stops executing the current macro if a
python-evaluation returns True.
+ Extension of the "Serial Plugin" with a "Read" action. The result is
stored in the variable "result" to process it with a Python script.
+ Added a COM-Server. With it you can generate events from other
applications through ActiveX for example.
+ Began work on a new "About" dialog. Really unfinished, but updated
the links to the new URLs.
+ The installer now will look if you have EventGhost running and prompt
you to close it before continuing the installation.
- Bugfix: Deleting some plugins from the tree resulted in an error.- Bitmonster
Changelog 0.2.6 (build 442):
- Bugfix: USB-UIRT plugin didn't work properly anymore.
- Bugfix: On some systems EventGhost didn't started, because a
special system information wasn't available.
- Bugfix: Joystick plugin could show an error-dialog behind the
main-window if you haven't attached any joystick/gamepad to
the system. This dialog is completely removed now.
- Bitmonster
Changelog 0.3.0 (build 479):
* Core thread code completely rewritten. This should make EventGhost faster
and more reactive under heavy load conditions. It also eases the writing
of advanced event schemes in the future.
* New option to automatically check at startup if a newer version of
EventGhost is available. You can turn off this checking in the general
configuration dialog.
* New action: "Jump" that does an unconditional jump to another macro and
optionally returns from there after executing this sub-macro. A "Jump If"
with the parameter "True" will actually do the same, but for convenience
this new action was added.
* New action: "System/Set system idle timer" that lets you disable and
re-enable idle monitoring of the OS power-management. If disabled, the
system will not go automatically into standby or turn off the display
after the idle timeout.
* Developer MonsterMagnet contributed two new plugins to control the
programs:
1. Foobar2000
2. Media Player Classic
Many thanks to him at this place.
* Some more fun with the "About Dialog". :)
* Added menu items under the help menu to go directly the Eventghost's
homepage, forum and wiki.
* Added menu item under the help menu to manually check if a newer version
of EventGhost is available.
* Lowered the memory footprint while EventGhost runs in the tray.
* Bugfix: Wildcards in events were not allways working correctly. If you
used the "Task" plugin for example, you couldn't make an event like
"Task.Activated.*" to trigger a macro everytime another program is
switched to.
* Bugfix: If EventGhost was closed through a system shutdown, the
cleanup-code was not working correctly.- Bitmonster
Version 0.3.1 is out!
Sorry, no changelog for this version. There were just too much changes to remember.
Download EventGhost 0.3.1 (build 568)
- Bitmonster
Version 0.3.2 is out!
Sorry, again no changelog for this version, but there are many new features and many bugs fixed.
Download EventGhost 0.3.2 (build 627)
Also notice, that I often release some intermediate releases of EventGhost, that are not published on SourceForge.net.
Please read about how to get the newest beta here.
- Bitmonster
It was a long time, since the last official release on SourceForge.
Version 0.3.3 is up now!
Download EventGhost 0.3.3 (build 809)
- Bitmonster
- Bitmonster
- Bitmonster
Version 0.3.5 had a small but severe bug. So I had to upload the 0.3.5b bugfix release:
Download EventGhost 0.3.5b (build 907)
Please update as soon a possible. (SourceForge needs some time to distribute it over the mirrors)
