Keyboard events
molitar
Keyboard events
Post by molitar »
Well I can't get a single keyboard event to work.. {ALT+ENTER} to toggle window.. {TAB} that hides text window. None of these keys are read by the application at all. And none are seen in the EVentGhost events. Is their a plugin that will actually emulate true keyboard because emulate does not work at all.
110220Volts
Re: Keyboard events
Post by 110220Volts »
try the HID plug in it should say the name of your Keyboard in the configure page so select that and then it should HID:xxxxx (Where XXXXX is the key pressed)
molitar
Re: Keyboard events
Post by molitar »
Ok it sees my Logitech G15 but it has two of them.. when I press the space bar for example nothing shows up. Ok I added the keyboard plugin can see events now but how do I send the keystrokes to the program? I have window selected and press a key with emulate keystrokes {Tabulator} and nothing happens even with alternate methods I can not get get the key stroke to work at all.
