Anyway to autorestart eventghost when it crashes?
My eventghost is periodically closing with no error message.
Re: autorestart eventghost
Regards
Prinz
Do you have tried to use the debug switch "-debug"? Using this switch al log file will be generated in the user directory.Fiasco wrote:Anyway to autorestart eventghost when it crashes?
Regards
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
CPU: Intel E5200
OS: WinXP SP3
I'm interrested with this option too !!
How do you activate it ? with the start exe ?
"EventsGhost.exe -debug"
Thanks in advance !
Bob
Thanks in advance !
Bob
Nobody can respond to this post ? It is not possible to have debug log in EG ? I can't beleive it....
Bob
Bob
Yes, that's exactly how you do it.
EventGhost.exe -debug
As Prinz said the log file should be in %appdata%\EventGhost\. (default in xp is "C:\Documents and Settings\someuser\Application Data\EventGhost\")
Is it not working or... ?
