W7 Media Center + Cyberlick BD plugin - how to control this?
lapilesos
Post by lapilesos »
i have a Drea...well question :) Using MCE plugin to send all comands to ehshell window works pretty well...BUT - all plugins (espetially Cyberlick one) does not react on MCE shortcuts. Does anyone have an Idea, how can I control this plugin in MCE?
-Should i simple remap some shortkeys to IR Commands?
-Or should i leave keyboard emulation on ( ARROWS and Enter/Esc) + MCE shortcuts? Or anyone have an Idea how can i extend MCEplugin to check if CyberlinkBD is running and then send "cyberlinkable" shortcuts?
It would be nice to know some Remote with hunderds of IR codes in one. So i will programm Harmony with it and use all those IRCodes to map them to Keyboardshortcuts?
My current "Hauppage PVR350" map did not have enought IR codes for it.
Thank you.
