two "instances" of eventghost
derelict
Post by derelict »
Hi
Is it somehow possible to run two instances of eventghost simultanously ?
The reason i'm asking is because of: http://www.eventghost.org/forum/viewtop ... 007#p12007
i would like to run the older eventghost version just to put the PS3 into standby mode and the newer eventghost version (with the new ps3 plugin which does not yet support putting the remote into standby) at the same time.
I've tried playing arround with the -configdir command line option. but had no luck... it always opened the eventghost version of the current running "instance" instead of starting a new process with the corresponding config.
Any help would be very much appreciated!
