I just purchased AVS GP-IR01BK remote:
http://www.newegg.com/Product/Product.a ... 6880121003
The logo on the remote says Mediagate.
I want to control XBMC with it (running on W7 64bit). Sadly, it seems that only a couple of buttons work (OK, forward, up/down). I installed EventGhost, but now I'm totally lost. Can someone tell me which remote plugin I need? The picture matches the CONCEPTRONIC remote, but mine is infrared, not RF and the plugin doesn't work.
And then, do I just add the XBMC plugin and I'm good to go, or is there something else that has to be done?
Thanks. I'm really lost here.
