maybe someone can help, cause i tried many things to find a solution for my problem, but i know not much enough how the data transfer is working to xbmc.
I just using eventhost and the old xbox remote controll for controlling xbmc for about 1 year and only have one main problem with it:
For the arrow buttons i add the command "automatic reapeat" so that it srolls long list of media files in xbmc.
This does not work, xbmx is only doing maybe 3 steps than stopping and this the whole time.
In the log window of eventghost is looks like it should with all default settings going faster after 3s and so on.
I just thought this will not work cause of the way this works.
But I setup now a different machine with win7 and build up the system new with latest eventghost and xbmc and the same remote and it works just flawesly without stops. I tried everything to figure out the problem so it must be something with the way eventghost communicates with xbmc. So maybe someone can help please?
Thanks in advance!
