This is a simple command line utility I wrote to issue commands to a Global Cache GC-100 IR controller.
You can use EG to send pre-defined IR and/or GC Sensor code/commands.
Setup is easy (in EG):
1) Create a folder
2) Create a Macro
|--> Select "Start Program"
3) Then browse to the destination of the gcIRcom.exe (where you
install/unzipped it to.
Usage:
simpleIRClient -p <protocol> -n <server> -e <endpoint> -m <moduleaddress> -c <connectornumber>
Where:
-p protocol - is TCP
-n server - is the string address or name of server
-e endpoint - is the port to listen on
-m module - is the IR module number
-c connector - is the connector on IR module
-g gcircom - is the native GC IR command string to send
Defaults:
TCP, 192.168.1.70, 4998, 2 and 1 - (You must specify the GC IR command string using the -g)
e.g.: e.g: gcIRcom.exe -p TCP -n 192.168.1.1 -e 4998 -m 4 -c 1 -g 36000,3,1,15,10,6,10,6,22,6,10,6,28,6,16,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,28,6,10,6,3100
On successful completion of the code, the GC-100 will send:
completeir,<module>:<connector>,ID.
Then terminate.
By: VortexRotor Enjoy!
The utility is rock solid and a readme is included in the zip file.
As time permits, I will wrap it into a plugin for future release for EG.
Enjoy!
Global Cache EG support
vortexrotor
- gcIRcom_v1.zip
- (142.45 KiB) Downloaded 197 times
jstplyn331
Re: Global Cache EG support
Just trying to understand I have everything down you have said Start Application then in the command line I posted what you said and after that I am curious as were to send out the IR command or were to input it to send out the IR command if you have a few minutes to explain i would great fully appreciate it. Thanks
Also I guess what I am trying to send is a Pronto CCF IR command thanks
