How do you add a delay between actions in a macro?
darbman
Post by darbman »
Hi all,
I am running 0.3.7.r1194 on windows xp sp3.
I need to add a delay in my macro between Ir sends to my direct tv receiver. (channel 11 sends the number one twice)
the codes come out to fast. I am using the usb-uirt plugin. could someone give me an example of how to do this. Could this be done with the timer plugin?
Darbman
jitterjames
Re: How do you add a delay between actions in a macro?
Post by jitterjames »
look for an action under the eventghost category called wait some time.
