Custom plugins required to be downloaded for these configurations is the Taskbar created by Pako for my needs
Custom OSD that will display on monitor 1 or 2 depending on if you have screen maximized it will display OSD on the second display.
Custom OSD shows Title, Current Playtime Bar, Current play time and End Time of the file being played
Custom Toggle Minimize, Maximize
Custom Maximize that sets taskbar to auto-hide and unhide when not maximized
Custom Volume OSD that displays a volume bar and percentage OSD
Volume OSD
<EventGhost Version="1387">
<Folder Name="Volume Controls">
<Macro Name="Volume Up">
<Event Name="DXusbPCR.Num2" />
MediaPlayerClassic.VolumeUp()
EventGhost.NewJumpIf(XmlIdLink(285), 2, True)
EventGhost.PythonScript(u'from eg.WinApi.Dynamic import SendMessage\nTBM_GETPOS = 1024\nFind_MPC_Volume_Ctrl=eg.WindowMatcher(u\'mpc-hc.exe\', u\'{*}Media Player Classic{*}\', u\'MediaPlayerClassicW\', u\'\', u\'msctls_trackbar32\', 1, True, 0.0, 0)\nhwnd = Find_MPC_Volume_Ctrl()\n\nM = 2\n\nif len(hwnd) > 0:\n if eg.globals.WindowsState == "Fullscreen": volume = int(SendMessage(hwnd[0], TBM_GETPOS, 0, 0)/7)\n if eg.globals.WindowsState != "Fullscreen": volume = int(SendMessage(hwnd[0], TBM_GETPOS, 0, 0)/5)\n eg.result = volume*M*u\'\\u2588\'\n volume2 = SendMessage(hwnd[0], TBM_GETPOS, 0, 0)\n eg.result2 = volume2\nelse:\n print "Window not found"\n eg.result = \'\'\n \nif eg.globals.WindowsState != "Fullscreen":\n eg.plugins.EventGhost.ShowOSD(u\'Volume: {eg.result} {eg.result2}%\', u\'0;-48;0;0;0;400;0;0;0;238;3;2;1;49;Lucida Console\', (255, 0, 0), (0, 0, 0), 0, (60, 150), 0, 2.0, False)\nelse:\n eg.plugins.EventGhost.ShowOSD(u\'Volume: {eg.result} {eg.result2}%\', u\'0;-48;0;0;0;400;0;0;0;238;3;2;1;49;Lucida Console\', (255, 0, 0), (0, 0, 0), 0, (60, 150), 1, 2.0, False)\n ')
EventGhost.AutoRepeat(0.29999999999999999, 0.29999999999999999, 0.0, 60.0)
<Macro Name="Volume Down">
<Event Name="DXusbPCR.Num8" />
MediaPlayerClassic.VolumeDown()
<Macro Name="Volume Mute">
MediaPlayerClassic.VolumeMute()
</EventGhost>Code: Select all
<Folder Name="Display Toggles">
<Macro Name="Toggle Maximize" Expanded="True">
<Event Name="DXusbPCR.Num9" />
Window.FindWindow(None, None, u'MediaPlayerClassicW', None, None, None, False, 0.0, 0)
EventGhost.PythonScript(u'from eg.WinApi.Dynamic import GetWindowLong, ShowWindow, SW_RESTORE, SW_MAXIMIZE, SW_MINIMIZE\nfrom win32gui import SetWindowPos\nfrom ctypes import windll\n\n# Check that we have a window to try to maximize/restore\n# Use Find Window action before this script!\nif eg.globals.WindowsState != "Fullscreen":\n if len(result) > 0:\n # Check if WS_MAXIMIZE bit is set\n if(GetWindowLong(result[0], -16) & 0x01000000):\n eg.plugins.EventGhost.ShowOSD(\'Maximized \' + eg.WinApi.GetWindowText(eg.result[0]), None, (255, 255, 255), (0, 0, 0), 0, (0, 0), 0, 3.0, None)\n eg.plugins.MediaPlayerClassic.ViewNormal()\n ShowWindow(result[0], SW_RESTORE)\n #Script Unhide Taskbar\n eg.plugins.Taskbar.SetAutohideOff()\n else:\n eg.plugins.EventGhost.ShowOSD(\'Maximized \' + eg.WinApi.GetWindowText(eg.result[0]), None, (255, 255, 255), (0, 0, 0), 0, (0, 0), 0, 3.0, None)\n eg.plugins.Taskbar.SetAutohideOn()\n ShowWindow(result[0], SW_MAXIMIZE)\n eg.plugins.MediaPlayerClassic.ViewMinimal()\n #Script Hide Taskbar\n')
<Macro Name="Toggle Minimize">
<Event Name="DXusbPCR.Num7" />
EventGhost.PythonScript(u'from eg.WinApi.Dynamic import GetWindowLong, ShowWindow, SW_RESTORE, SW_MAXIMIZE, SW_MINIMIZE\n \n# Check that we have a window to try to minimize/restore\n# Use Find Window action before this script!\nif eg.globals.WindowsState != "Fullscreen":\n if len(result) > 0:\n # Check if WS_MINIMIZE bit is set\n if(GetWindowLong(result[0], -16) & 0x20000000):\n eg.plugins.EventGhost.ShowOSD(\'Minimized \' + eg.WinApi.GetWindowText(eg.result[0]), None, (255, 255, 255), (0, 0, 0), 0, (0, 0), 0, 3.0, None)\n ShowWindow(result[0], SW_RESTORE)\n else:\n eg.plugins.EventGhost.ShowOSD(\'Maximized \' + eg.WinApi.GetWindowText(eg.result[0]), None, (255, 255, 255), (0, 0, 0), 0, (0, 0), 0, 3.0, None)\n ShowWindow(result[0], SW_MINIMIZE)')
<Macro Name="Python Script">
EventGhost.PythonScript(u'from win32gui import SetWindowPos\nfrom ctypes import windll\n\n#Script Hide Taskbar\nTOGGLE_HIDEWINDOW = 0x80\nhandleTaskBar = windll.user32.FindWindowA("Shell_TrayWnd", "")\nSetWindowPos(handleTaskBar, 0, 0, 0, 0, 0, TOGGLE_HIDEWINDOW)\n\n#Script Unhide Taskbar\nTOGGLE_UNHIDEWINDOW = 0x40\nhandleTaskBar = windll.user32.FindWindowA("Shell_TrayWnd", "")\nSetWindowPos(handleTaskBar, 0, 0, 0, 0, 0, TOGGLE_UNHIDEWINDOW)')
<Folder Name="Show OSD" Expanded="True">
<Macro Name="Display OSD">
<Event Name="DXusbPCR.Num3" />
EventGhost.PythonScript(u'mpc = eg.WindowMatcher(u\'mpc-hc.exe\', None, u\'MediaPlayerClassicW\', None, None, None, True, 0.0, 0)\nhWnd = mpc()\n\nif len(hWnd) > 0:\n from eg.WinApi import GetWindowText\n title = GetWindowText(hWnd[0])\n eg.result = title.split(".mkv ")[0] \n\nFind_MPC_Time=eg.WindowMatcher(u\'mpc-hc.exe\', u\'{*}Media Player Classic{*}\', u\'MediaPlayerClassicW\', None, u\'Static\', 2, True, 0.0, 0)\nhwnd = Find_MPC_Time()\n\nif len(hwnd) > 0:\n if eg.globals.WindowsState == "Fullscreen": howManyBars = 60\n if eg.globals.WindowsState != "Fullscreen": howManyBars = 80\n\n timeE,timeR = eg.WinApi.GetWindowText(hwnd[0]).split(\' / \')\n secArray = timeE.split(\':\')\n secArrayTotal = timeR.split(\':\')\n secondsTotal = int(secArrayTotal[0])*(60)+int(secArrayTotal[1])\n secondsElapsed = int(secArray[0])*(60)+int(secArray[1])\n percent = (secondsElapsed*howManyBars)/secondsTotal\n osd = eg.result + "\\n \\n" + "[" + "|"*(percent) + " "*(howManyBars-percent) + "]" + "\\n" + " "*30 + timeE + " / " + timeR\n \n if eg.globals.WindowsState != "Fullscreen":\n eg.plugins.EventGhost.ShowOSD(osd, u\'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial\', (0, 255, 255), (0, 0, 0), 4, (0, 0), 0, 1.0, False)\n else:\n eg.plugins.EventGhost.ShowOSD(osd, u\'0;-64;0;0;0;700;0;0;0;0;3;2;1;34;Arial\', (0, 255, 255), (0, 0, 0), 4, (0, 0), 1, 1.0, False)\n mpc = eg.WindowMatcher(u\'mpc-hc.exe\', None, u\'MediaPlayerClassicW\', None, None, None, True, 0.0, 0)\nhWnd = mpc()\n\n\n')
<Folder Name="Windows State" Expanded="True">
<Macro Name="Windows State" id="285">
EventGhost.PythonScript(u'from win32gui import GetWindowPlacement\n\n#SW_SHOWNORMAL = 1\n#SW_SHOWMINIMIZED = 2\n#SW_SHOWMAXIMIZED = 3\n\nFindWin = eg.WindowMatcher(None, None, u\'MediaPlayerClassicW\' , None, None, None, True, 0.0, 0)\nhwnd = FindWin()\n\ndef GetWindowStatus(hwnd):\n showList = (None, "Normal", "Minimized", "Maximized")\n placement = GetWindowPlacement(hwnd)\n #unrem the below line to display the placement values that you need for the if placement[4] line\n #print placement\n \n if placement[4] == (1671, 1050, 2951, 1770):\n return "Fullscreen"\n else:\n return showList[placement[1]]\n\neg.globals.WindowsState = GetWindowStatus(hwnd[0])\nprint "Windows State = " + eg.globals.WindowsState')
